1995 z28
Old 02-21-2015, 02:59 PM
Camaroforlife's Avatar
Originally Posted by torque_is_good
hey, I wasn't passing judgement :-)
if you aren't in a hurry, definitely take your time shopping for wheels/tires.
At the end of January and early Feb is when suppliers are hurting for customers and it's before the Spring rush for those in colder climates.
Also, you have a 95 as do I. Any rim you buy will probably need the hole enlarged by 1/4 inch in order to fit onto the hub in the rear. If you enlarge all 4 rims then you can rotate front with rear (if you use the same size)
Seriously, check out the Sumitomo HTR AS and the best prices I've found are at discounttiredirect.com and always, free shipping ( I sound like a paid spokesmodel)
I stumbled upon the G Force one time at Sams Club when they were dumping inventory and I got them for $70 each 275 40 17 but Wally world won't install them on the car as they are not stock size
Thanks for the input, I will definitely look at those tires, I just need new rims, suggestions would be great, and should I do 17's all around? what's ya'lls setup?
  #32
Old 02-21-2015, 03:03 PM
I was thinking about doing black interior, but I figured it would cost too much, unless I found someone paying out a car close by. Might just get a new headline as that is the only problem with the interior.
Guy in my town paints cars as a job in his garage, he does great work. He quoted me 2k for a full paint job, any color, he takes it all the way to bare metal, does great body work, and preps it well. He also said it comes with a life-time warrenty. (As long as he's alive lol)
  #33
Old 02-12-2016, 04:52 PM
Updating with some pictures, been awhile since I've posted. Been so busy with work and school.
Car has been painted, (not the best- plan on taking it back to get repainted at some point) ; Clutch has been upgraded with a RAM HDX with new flywheel. I fixed all oil leaks, from rear main seal, rear of intake manifold, and oil pressure sensor.
I have big plans coming soon, Looking into heads/cam/ and P&P'd intake, possibly #30 injectors. I have many questions as well.
  #34
Old 02-12-2016, 05:30 PM
Trying to make the "light-up" Berger panel. Dremel'd out "CAMARO" and painted it satin. Trying to find what to place on the back to cover the holes and diffuse the lights. I have tried 1/4 in Plexiglas and sanding it but it isn't to my satisfaction. Anyone have any ideas on this?
96WAGON
08-29-2013 11:39 PM
jpowers
02-22-2010 07:43 PM
Camaro95
09-17-2009 12:05 AM
pegman456
06-04-2008 08:15 PM
chadscamaro
05-21-2004 07:57 PM
Quick Reply: 1995 z28
