would like some info
Old 04-25-2015, 08:14 PM
redironman's Avatar
Default would like some info
I went to auto zone for my check engine light and and they said the code was for my driver modual. Does any one know what that means?
Old 04-25-2015, 09:20 PM
what year is you camaro and what engine and trans? did they give you a code number?
Old 04-25-2015, 09:29 PM
redironman's Avatar
Its a 95 z28 v8 the code he gave me was 29 he said it was driver module and another code 32. The EGR valve. To add a couple other common things going Wrong with it is the coolant light stays on even though there's water in the radiator and also the temp gauge seems like it always stays low.
Old 04-25-2015, 11:57 PM
Camaro blood runs through's Avatar
These should help.1992-95 LT1 trouble codes also with the fluid level , it is an easy fix. Sensor is in the top left (looking at it from the front) under your two hoses . Easy to get to if you remove the battery. Drain fluid level a little pull over the the clip that holds it in, replace sensor with new one. Make sure you get it all the way in and and the clip is on right. It can blow out going down the road and leave a wet mess in the engine bay
Old 04-26-2015, 12:22 AM
redironman's Avatar
Thanks man I'm going to try that tomorrow.
Old 04-26-2015, 12:28 AM
Sure thing. Hope it helps. If you do not pull the battery during install it is a good idea to take the negative cable off after doing it to reset the computer. On mine, if I don't do it, the light will stay on for a good while after replacing it. Need to wipe the codes and lights clean on mine for some reason. Don't forget to bleed the air out of the coolant lines when you refill also.
Old 04-26-2015, 11:44 AM
Code 29 means the PCM sees a problem on The control lead going to the AIR pump relay. The PCM monitors this lead and expects to see 12 Volts when the relay is not activated. When the PCM calls for the AIR pump to operate it applies a ground to the lead and expects the voltage on the lead to be close to zero. If these conditions are not met, the PCM will light the MIL. Check fuse #7 (under hood panel) and the wire going from the PCM terminal A14 and pin E2 on AIR pump relay.
Old 04-26-2015, 12:03 PM
go here https://www.mediafire.com/?40mfgeoe4ctti and download the factory service manual file 94svcman also check out 4th Gen LT1 F-Body Tech Aids and https://camaroforums.com/forum/93-02...62/#post557634 for misc info
RodneysPhoto
03-28-2011 01:44 PM
camarogurl843
82-92 V6 Tech
11-04-2010 02:44 PM
Skidoo03
10-18-2010 06:39 PM
Homestar1217
06-27-2009 08:37 PM
vinnyboombots
04-04-2009 03:14 AM
Quick Reply: would like some info
