wiring problem - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
Thread Tools Search this Thread
Old 02-17-2012, 12:08 AM
Default wiring problem
Hi everyone
I have a 1995 camaro with a 3800 series ll engine I swapped the auto trans out with a t5 but I don't know what to do with the wiring. can anybody help?
Old 02-17-2012, 12:11 AM
BasicConcepts's Avatar
Technical User
you need the computer and engine wiring harness from a manual 95
Old 02-17-2012, 12:15 AM
^^^ agree you need the harness from a manual trans 95 camaro, not sure if it will need to be a v6 harness. is the computer re burned or changed to match a manual trans. im not sure how it will react to not getting the readings from a manual.
Old 02-17-2012, 12:22 AM
Technical User
you can get a wiring harness and computer from a 95 3.4 with the T5
Old 02-17-2012, 10:02 AM
The 95 3800 was GMs first fully compliant OBD2 Fbody. Trying to use a 3.4 OBD 1.5 harness would be a nightmare; the ignition system and even the firing order are different. The 95 and 96 PCMs are hard to flash and most tuners will not mess with them. To add to the complication GM did not make a 3800 5 speed in 95.
Motor should run your just going to set the check engine light with a bunch of tranny codes. Talk to a local tuner he may be able to tune out those codes. I am not sure why most tuners do not like the 95-96 boxes but maybe switch the PCM to not report tranny codes is doable? If you could get the codes turned off you could just terminate the wires to the tranny. The other option would be to swap in a 96 or 97 harness and PCM. Problem is since there was only about 5000 95 3800 made there is no real info on what is compatible and what is not.
If you get it all figured out let us know!!
Reply
Thread Thread Starter Forum Replies Last Post
Wiring Problem. BillsFan727 93-02 General 4 06-26-2012 01:48 AM
Wiper Wiring Problem GetUpTop General Tech 2 04-21-2009 08:34 PM
wiring problem chris n 67-69 V8 Tech 0 11-30-2008 10:47 PM
camaro wiring problem?help? inky21 82-92 General 1 10-20-2007 03:50 AM
Wiring Problem maddoghowe 82-92 General 0 06-13-2007 12:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
