What to look for on a 4th gen
Old 09-02-2015, 11:06 PM
Mark_k's Avatar
Cool What to look for on a 4th gen
Hello, I am going to look at a 4th gen tomorrow. It has a LT1350 with a 6 speed in it. Is there anything that I should be on the look at that are problematic on these cars? The guy is askin 3k, so thinking either a steal or something wrong with it.
Old 09-02-2015, 11:57 PM
what year, hard top?
Old 09-03-2015, 12:12 AM
Mark_k's Avatar
Thinkin 97, it was dark when I saw it, so didn't check the year on the vin. It's a t-top firebird. I'm goin back in the mornin to look at it and talk to the owner.
Old 09-03-2015, 12:36 AM
woh, like you said must be something. or could just need tires, brakes, ball joints. stuff like that that cost allot in a shop but if owner does it not so much.
Old 09-03-2015, 12:43 AM
Mark_k's Avatar
My lift is down so I can't really look into it much, so wasn't sure if there were problematic areas with them that I should make sure and pay more attention to.
Old 09-03-2015, 05:17 AM
Mark_k's Avatar
How much power can I make before I have to worry about flex being a t-top?
Old 09-03-2015, 08:55 AM
it flexes at stock. without damage i would think its up there. 400+ sub frame connectors take care of that. weld in are best.
Old 09-03-2015, 10:16 AM
MKCoconuts's Avatar
Make sure the clutch engages and disengages smoothly, and if possible, disconnect the slave cylinder and shine a flashlight up onto the fork to inspect for any cracks on it. The forks are know to crack and eventually break since they're cast. A replacement, if you can find it, will set you back a pretty penny.
Old 09-03-2015, 11:07 AM
Mark_k's Avatar
Went and looked at it in the day light. I'm not sure about it. Both bumper covers need replaced and the clear is cracking. I haven't talked to the owner yet cause not sure if it's somethin that would work for what I'm looking for. If you guys were wanting to build a lower budget 1/4 mile car, would you waste your time and money with somethin like this? Thanks
Old 09-03-2015, 11:27 AM
95 camaro 406's Avatar
if you want to build a low cost 1/4th mile car ,look for one that may need an engine but evrything else is good 1000.00 probley ,there are many .rust free z28 out there ,then find a used lt1 an build it to 400hp ,graigs list 3000.00 thats to much unless its got low miles an runs good ,most cars that have a beat up .body,have even worse machanical issues ,so if you want find one needs a rebuilt engine with a good tranny ,,check for rust to under the car ,1500.00 or less ,probley cost another 2500.00 to build the engine where i live there is ton of them,you got to thin k whats a low cost 1 4/th mile car ,as that alone can cost,find the one that needs minumal work done i had seen one ,all it need was tranny rebuild wanted it gone 800.00 it had 98.000,that you will need to do alot of searching ,but you can get there ,where . live makes a .diffrence ,as far as cost ,grais .list put your price an an see what they have ,i had seen a .ss with 87.000 miles looked sweet was $5000.00 if it needed nothing ,thats a great car for 4/th mile
Quick Reply: What to look for on a 4th gen
