Valve covers. Easy or to the shop?
Just wondering how easy the valve covers are on a 97 camaro. Mine are leaking pretty bad. They look pretty cozzy and tucked away. Is it worth doing in my garage over a weekend or should i just take it to a shop.
they don't look to bad to me ,if you got the tools an a few beers ,guys say there pretty easy to work on ,you can do it ,you got a deal on that car yes a mech should cost no more then 2 hours labor ,if you buy the gaskets,add 50.00 per hour hear
go here and download the factory service manual. use the 96 one https://www.mediafire.com/?40mfgeoe4ctti it should work fine.
I pulled mine in 09. The drivers side is not too bad. I remember the passengers side being a lot more work. I think the engine lift ring in the back on the passengers side complicates things.
Have you tried re-torqueing them? Again if I remember right it is not a gasket but a seal and they fail very rarely and to have two fail on one car would be surprising. The only way it would make sense would if the motor was a little sludged up and the oil was pooling in the valve cover because the return holes where partially blocked.
