tools needed to remove rear end
Old 09-08-2014, 11:00 PM
fbodyrs96's Avatar
Originally Posted by v64thgen
Do you have a link to a good site to decode the vin for the car this rear came form?
They charge now, but this will tell you every option the car came with by the vin http://www.compnine.com/vid.php
  #42
Old 09-09-2014, 06:45 AM
fbodyrs96's Avatar
heres mine
Vehicle: CAMARO CONVERTIBLE
Year: 1996
Build Date: 1995-12-21
Found 7,457 vehicles matching your year and model in our database.
RPODescriptionMatchesUA6THEFT DETERRENT SYSTEM ANTI-THEFT(UA6)
6,975
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
7,457
U1C RADIO,AM/FM STEREO,C.D. PLAYER,ETR,INCLUDES CLOCK STEREO/CD PLAYER(U1C)
4,713
U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS(U62)
7,421
U73 ANTENNA,FIXED FIXED ANT(U73)
7,307
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
5,387
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
7,127
Y3F SALES PACKAGE RS CAMARO UPFITTER CAMARO RS(Y3F)
927
Y87 PERFORMANCE ENHANCEMENT 3800 GT 3800 GT(Y87)
1,260
1AY Unk.3,659
1ST Unk.8521
0Q MOLDING COLOR,ARCTIC WHITE (10Q)
1,323
10U EXTERIOR COLOR,ARTIC WHITE (10U)
1,547
52I INTERIOR TRIM LIGHT NEUTRAL (52I)
2,397
522 TRIM COMBINATION - LEATHER, NEUTRAL (522)
1,458
56T VINYL TOP COLOR,MED NEUTRAL (56T)
2,117
6AN COMPONENT FRT LH COMPUTER SEL SUSP SUSP(6AN)
4,042
7AN COMPONENT FRT RH COMPUTER SEL SUSP (7AN) SUSP(7AN)
4,0428
TC COMPONENT RR LH COMPUTER SEL SUSP (8TC) SUSP(8TC)
4,0489
TC COMPONENT RR RH COMPUTER SEL SUSP (9TC) SUSP(9TC)
4,048
AG1 ADJUSTER,SEAT,6-WAY POWER,DRIVER(60-40)(VAR 2) 6-WAY PWR D/SEAT ADJR(AG1)
5,165
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
7,421
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
7,457
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
6,975
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
7,388
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
7,219
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90)
7,356
B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
5,395
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
6,430
CAE Unk.724C60AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
7,455
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
7,069
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
6,822
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
5,948
F41 SUSPENSION,FIRM RIDE HANDLING,FRONT AND REAR FIRM RIDE & HANDLING SUSP(F41)
4,123
GU6 AXLE,REAR,3.42 RATIO 3.42R(GU6)
2,182
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXe(G80)4,630
IP2 TRIM,INTERIOR DESIGN (IP2)
4,302
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
4,594
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
7,417
K68 GENERATOR,105 AMPERE 105 AMP(K68)
4,123
L36 ENGINE GAS, 6 CYL, 3.8K, MFI, V6, HO (ERV6 SERIES) 3.8K(L36)
4,087
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS(MX0)
6,022
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
5,986
NF2 EMISSION SYSTEM,FEDERAL,TIER 1 FED EMIS SYS(NF2)
5,948
NG5 REGISTRATION EMISSION, CERTIFICATION, FIFTY STATE (50) FIFTY STATE U.S. EMIS(NG5)
6,822
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
7,165
N96 WHEEL,16X8(CAST ALUMINUM) AL WHL(N96)
5,360
QCB TIRE ALL P235/55R16 BW R/PE ST TL AL2 96T TIRE(QCB)
3,242
R7A Unk.6,826
R7R Unk.905
STEPLANT CODE- ST THERESE, PQ, GM OF CANADA ST THERESE,GM OF CANADA PLANT CODE(STE)
7,421
T96 LAMP,FRONT FOG FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TOURING YP6) FRT FOG LP(T96)
7,417--0
Rarity...
There are 4 1996 CAMARO CONVERTIBLE vehicles (0.054%) matching your exact options list. There are 8 (0.107%) with at least as many options.
The rarity of your vehicle is based on an exact match of your options for your year and model.
  #43
Old 09-09-2014, 08:49 AM
v64thgen's Avatar
That's a pretty cool report.
Regarding one of my earlier posts the shop had to do nothing special to make the rear work with my car, they used whatever parts were in better condition between my rear and the junk yard rear and everything connected up with no problems. ABS works and everything.
  #44
Old 09-09-2014, 10:19 AM
v64thgen's Avatar
I just spoke to my shop about replacing the clutch packs in this rear, they said probably $200-$300 in labor and the parts are around $100. No they haven't already gone out, I just like to be prepared. Is that a job that is better left for the pros, or could someone like me (not a pro but capable with a wrench) get it done?
  #45
Old 09-10-2014, 06:57 AM
older posi units clutch pack can not be rebuilt. not sure about the newer units.
  #46
Old 09-10-2014, 03:45 PM
v64thgen's Avatar
is there a way to determine if the clutch packs in mine can be rebuilt? Other than saying oh **** this wont work when its apart?
the car i took the rear from should not have had posi, so i dont really know what year car it is out of.
  #47
Old 09-18-2014, 10:22 AM
v64thgen's Avatar
finally got around to painting the calipers
  #48
Old 09-19-2014, 10:45 AM
MKCoconuts's Avatar
Is the parking brake part of the caliper or is it the separate style that sits within the rotor?
  #49
Old 09-19-2014, 04:20 PM
v64thgen's Avatar
Separate style that sits within the rotor.
  #50
Old 09-20-2014, 11:11 AM
MKCoconuts's Avatar
I'm pretty sure they switched to that style in '98, but may have been '97. So that narrows it down a little bit.
Quick Reply: tools needed to remove rear end
