Timing Cover Gasket, anyone know how?
Old 04-07-2013, 12:45 AM
95ConvertibleRo's Avatar
Default Timing Cover Gasket, anyone know how?
Mine is leaking on my 95 3.4 engine, before i try to do it is there an instructional here on this forum? thanks!
Old 04-07-2013, 02:56 AM
water pump base is timing cover, have a look here. https://camaroforums.com/forum/93-02...03/#post665343
Old 04-07-2013, 02:58 PM
Thanks so much for the response. I posted on three different forums and you are the first to finally reply.
I guess this isn't so tough to do. Are those pics from a Haynes or Chilton Manual? Maybe I should get one.
Thanks again!
Old 04-07-2013, 04:43 PM
factory service/shop manual. you would want one for your year. way better than aftermarket books but a little harder to understand. never open the tool box without one.
Old 04-07-2013, 06:48 PM
I bought one online but it turns out its for the 3.8 instead of 3.4 engine. You're right, it is very confusing and more so when its the wrong engine
Old 04-07-2013, 07:21 PM
I find that free is usually better: https://camaroforums.com/forum/camar...94/#post666176
Old 04-07-2013, 07:37 PM
Do you have one for the 1995, I don't see it there?
Old 04-07-2013, 07:39 PM
lol, sometimes free isnt so good. you can go by the 94 for almost everything, ecm is the big difference.
Old 04-07-2013, 07:53 PM
So there's a difference between the 94 and 95 3.4 water pump procedure? Don't think so.
Old 04-08-2013, 08:14 PM
Should I go ahead and change the oil pan gasket as well since it looks like I do need to detach it anyway. Thanks for the help guys !
parmleystylez
11-28-2011 10:07 AM
Genes
02-21-2011 12:02 PM
LT1ChevyBoy
02-03-2011 02:04 PM
wicked94z28
01-31-2011 06:32 AM
Sevenpelicans
12-06-2007 11:07 AM
Quick Reply: Timing Cover Gasket, anyone know how?
