Things to check before buying
I'm going to look at a 02 Camaro on sunday. Is there anything I should look at other then the regular stuff. Each model of car have their own kind of problems,what are the 4gen's??
Try to get Carfax report, it can give some insight as to region/state etc, like to spend a lot of time underneath: signs of leaks/rust, damage from going over the curb, drive it long enough to see if it over heats, check fluids, ask for maintenance records check for signs of quick repaint, is being flipped or is it a 1, 2, 3 owner car..... smellsof mildew, check all features, don't play radio so u can hear strange noises etc
wouldn't the carfax show a record of flood damage /repair to the vehicle? What are some signs of flood damage? Maybe rusted seat brackets,smell,rust on the bottom of the car? that's all I can think of. any other opinions would be helpful
I see in some of the guys pictures he has a convertible Camaro,vet,and something in the garage. He might be a flipper.
you want to check it couse mabey mabey not ,you want to check the engine for leaks under the car for rust ,some states have a 60 point check list or also have pre buy inspection ,if they don't want you to do any of that ,theres something wrong with it
I went to look at the Camaro today. It looked nice from the outside. The first thing I saw was the rear tires were looking out of place, well he had the wrong size rims/tires on it and they rubber the fender wells ALOT. He fired it up and it had a little ticking that didn't go away. I got inside and the driver seat was stuck in one position and some type of red fluid on the armrest, then I grabbed the steering wheel..... it wiggled and moved. So we ride down the road and I hear the rear-end whining as I get on n off the gas. (He said they all do that) RRRRRRR they shouldn't! It drove out pretty good,I couldn't really beat it like I wanted to but I got the feel for it.
Now fixing the steering collom might not be to much work, or even fixing the driver seat, but I'm not going to redo the rear end AND pay 9-10K so I walked away.
