Test-N-Tune, X half a dozen!
Track was pretty full and we started late, so i only got 2 runs. First run:
Far lane: 98 Z28, built M6, 4.10s, VR reverse split cam, stock heads, full exhaust, bolt ons, 315 Nitto 555Rs on the back.
Near lane: Very close to the same except 3.73s, Cam Motion cam, and ET Streets on factory wheels.
Time slip:
Left........Right
.468.......105 Reaction
1.94.......1.65 60ft
7.98.......7.54 8th E.T.
90.4.......90.2 8th MPH
12.26.....11.85 1/4 E.T.
115.9.....114.1 1/4 MPH
Here's some pics from this race:
2nd race:
Far Lane: Z28, 6.0 LQ4, built M6, 12 bolt with 4.56, Pat G cam, TFS 215 heads, bolt ons, Mufflex exhaust, 28 inch ET Streets
Near lane: Same as near lane above
Time slip:
Left.......Right
.569.......117
2.15.......1.71
8.37.......7.63
89.5.......90.0
12.63....11.95
117.5....113.8
Time slip:
Left........Right
2nd race:
Time slip:
Left.......Right
.569.......117
2.15.......1.71
8.37.......7.63
89.5.......90.0
12.63....11.95
117.5....113.8
Couple more videos:
As a sidenote, I got my shifting issues worked out. Turns out my mph on my trans tables was off by about 5 mph and it was causing all hell to break loose at WOT. Its fixed now so next time the car should see some honest mid 11s cam only. Waiting for the heat to die down some.
Fast Forward: Went back to the track this past friday. Finally got the car off the limiter. Best run was still about 11.8x. Couldn't get it to go any faster. I had a new best 60ft of around 1.58 and a new best trap of 115. DA was about 1650 at the time of the runs. Couldn't seem to get the ETs down though. My only 2 vids from that night are ****ty but I will link one from someone else:
Car was filthy: Right lane
Left lane:
Left lane:
Fast Forward Again: Well we headed back out. Car ran a new best, but still had more in it. Couldn't get it to leave good. Here are the slips in order:
60ft...........1/8....................1/4
1.65......7.58/89.5...........11.94/112.7
1.65......7.55/90.6...........11.87/113.5
1.73......7.62/90.8...........11.93/113.9 Spun some out of the hole.
1.62......7.51/90.2...........11.84/113.6
1.62......7.47/91.0...........11.77/113.6
1.62......7.47/91.1...........11.77/114.9
Pics and vids:
Pics and vids:
4th Trip out: Track altitude: about 250 ft, DA for the night: about 2250. Yeah it was muggy with about 80-90% humidity. But we ran anyway for fun. Car ran good for the weather I thought, and pulled the driver tire 6-8 inches every run. Felt awesome :drive:
Here's how the slips stacked up:
Time...7:14.....7:18.....9:08.....9:34.....9:40... ....9:49
60'.....1.591....1.602...1.581....1.590...1.596... ..1.608
1/8.....7.350....7.342...7.316....7.344...7.321..... 7.327
1/8.....92.48....92.66...92.76....92.47...92.91..... 93.06
1/4....11.573..11.539..11.525..11.568..11.526...11.5 17
1/4....116.82..117.13..117.14..116.55..117.08...117. 59
And a couple of vids:
Since the last run it has a Fast92, AI 243s, PA Racing K member, Midwest bumper supports F+R, Strange 12 bolt. I was running about 3/4 tank of gas and an ice chest in the back. I know the 12 bolt is slowing me down some (over the previous runs) but I drove home so it's worth it Car is also tuned by a rookie tuner (me) and is set to conservatively shift around 6400. It ran exactly how you would find it any day on the street. Nothing added or subtracted.
Have run recently about 10 more passes. Changes are: Lightweight battery, Midwest chassis drag bar, speed inc carpet, sjm abs delete, firecore50 wires.....ET streets are bald and it was acting funky coming out of the hole but I did get a new personal best, 1.56 60ft, 7.20@95. Track wasn't running 1/4 at the time but I'm predicting it was a legitimate 11.30 pass. New changes are removing inner fender supports, removing front sway bar, aluminum radiator, and a full 17"Racestar setup. Inching closer to 10s NA I hope.
Here's some eye candy:
Stock carpet ready to be pulled:
Pulled the gauges to delete the idiot lights:
Letting the new carpet breathe, it does still have some padding under it, but it is a little louder then stock:
Found under the stock carpet.....winning!!!
Lightweight battery getting its first charge:
Simple aluminum flat bar hold down:
