Seat removal
Old 07-27-2010, 06:14 PM
Ceelo912's Avatar
Default Seat removal
im tryna remove my front drivers seat and having trouble. i got the two screws out the back but cant see whats holding it down in the front can anyone help thanks
Old 07-27-2010, 08:29 PM
Chaotic94's Avatar
September 2011 ROTM
Uhm two nuts are holding them down... There are black caps covering them up so that they don't scratch anything. Remove the caps and you'll be able to unscrew the nuts holding it down.
Old 07-27-2010, 08:43 PM
Ceelo912's Avatar
i took the two out but its still not tryna budge and cant really see under the front of the seat to see what else is under there holding it down
Old 07-27-2010, 08:44 PM
Ceelo912's Avatar
i got the two in the rear and was wondering what was holding it down in the front.
Old 07-27-2010, 09:01 PM
Grandpaswagon's Avatar
There are four nuts/bolts. Two in the back and two in the front. You say that you go the rear two out. Now push the seat all the way to the rear and you should be able to see the two nuts in the front. They are at the front edge of the sliding tracks.
Old 07-27-2010, 09:30 PM
Ceelo912's Avatar
ok thanks so much
Old 07-27-2010, 09:52 PM
RedKnight's Avatar
If it's a power seat, after you unbolt everything don't forget about the wire connection before you pull out the seat too exhuberantly.
wesman98
09-01-2013 09:08 AM
Chevynutz
01-22-2012 07:19 PM
yzair
04-07-2011 06:09 PM
69 Conv
04-09-2010 08:50 PM
kellyw66
05-01-2007 10:59 PM
Quick Reply: Seat removal
