Right Blinker
Old 03-06-2010, 02:54 AM
Kalika's Avatar
Default Right Blinker
This is my first camaro so I am having a little trouble finding where the bulb is in an 02. I unbolted the bracket so I can see easier but still have a hard time. Any help would be greatly appreciated. Thx
Old 03-06-2010, 07:41 AM
should be at the back of the light fixture. may have to take the front lower facsial off to get to it.
heres a couple answers i found.
Answer
1. Jack up car and support on jack stands (or use ramps)
2. Remove three screws securing under-cover to air dam.
3. Grip the light bulb socket and twist while compressing the locking clip.
4. Pull bulb straight up out of the socket and replace.
Answer
I've just done our 2002 Camaro front left turn bulb after discovering this answer here - but it's even easier than the above I think...
The piece of plastic that fills in under the front of the car is held to the front fender, the wheel well liner and the air dam with a number of screws. There are also two splits in this cover immediately adjacent to 2 of these screws - if you remove just the two screws that are behind the air dam that connect the black plastic to the finder, you'll find that you now have a small door that will hinge downwards to let you get your arm in.
Old 03-13-2010, 10:59 PM
Kalika's Avatar
Thanks, I will definitely do that.
94z
11-10-2008 09:21 AM
ledzeprokon6
10-14-2008 06:37 PM
dletner
09-21-2008 06:23 PM
94z28chevy
06-14-2008 02:45 PM
LOU97RS
04-02-2007 10:48 AM
Quick Reply: Right Blinker
