Replaced BCM, now wont start, and have security light
Old 07-21-2012, 04:26 PM
PCweber's Avatar
Default Replaced BCM, now wont start, and have security light
I had the classic relay clicking in my BCM so I got one for $10 at U Pull It. Installed ti,was happy, etc., then went to start the car.... No dice and security light is on. Is there a "mate" process to changing the BCM?
Old 07-21-2012, 04:45 PM
The bcm can only mate with one key. The only way you can use a used BCM is to have the key that came with it, or a least know the value of the resistor pellet. The BCM mates with the first key it sees and will not mate with a different one. In other words, the BCM mates with the key, the key does not mate with the BCM.
Old 07-21-2012, 04:54 PM
There are 15 different resistor values, 14 left to go now.
A locksmith can determine the value to match the BCM by using what's called an "interrogator", but they don't do it for free.
Old 07-23-2012, 01:11 AM
Massey's Avatar
GM can flash the bcm to accept your old key but that will run you $300 plus the towing to get your car there. Do you still have your old bcm? If so look at my post on fixing them. It is simple and is a really common failure on these cars.
Massey
Old 07-23-2012, 07:19 AM
^^^ thread massey speaks of is found in the how to and faq sticky at the top of the 4th generation general section. go here and look at number 11 https://camaroforums.com/forum/93-02...62/#post557634
Old 07-23-2012, 06:15 PM
Massey's Avatar
Originally Posted by craby
^^^ thread gorn speaks of is found in the how to and faq sticky at the top of the 4th generation general section. go here and look at number 11 https://camaroforums.com/forum/93-02...62/#post557634
That would be MASSEY Not Gorn. Sorry I didnt linky the thread my iPad does not like posting copied web links.
Massey
Old 07-23-2012, 06:36 PM
Guess that's what can happen when you're livin in "Tokeland".
Old 07-23-2012, 09:45 PM
lmao,,,, sorry massey we dont see you often,,, lol,,,i know, i know, i shoulda known. i changed it for yah
Old 07-23-2012, 09:47 PM
lol, i got the link right. i should get points for that at least
Old 07-24-2012, 06:41 PM
Massey's Avatar
*hands Craby a set of points*
Massey
chevydiva816
09-13-2011 01:39 PM
rwing7486
07-23-2008 11:03 PM
JOV_Camaro
05-17-2008 04:18 PM
Quick Reply: Replaced BCM, now wont start, and have security light
