Rear end Price
Depends on your area and if its an original V8 Limited slip or an open diff.
Car-Part.com--Used Auto Parts Market
93-02 should fit, if you have traction control you will want a traction control rearend if not you will want a non traction control rearend. tc rearend has a sensor on each wheel non tc has one in the center section. call around to your local wrecking yards and see if you can get lucky, may find one for couple hundred. non posi/open rearend will go for about 200 if demand in your area is light.
CasperOn20s
03-21-2007 06:52 PM
