really annoying door panel window switch
Old 07-25-2014, 11:39 PM
warmeck's Avatar
Default really annoying door panel window switch
my door panel window control plastic piece keeps popping off, i believe there is only one latch that is barely attached the others arent on their. Is there anyway to stop it from popping off without super gluing it down?
Old 07-26-2014, 12:08 AM
should be like plastic catches to hold it down. some pictures in this link
http://www.firebirdnation.com/pdf/windowreplacement.pdf
Old 07-26-2014, 03:36 PM
warmeck's Avatar
yeah those plastic pieces aren't there anymore idk what the previous owner did to them, he probably cut them off.
Old 07-26-2014, 03:59 PM
they break off pretty easy after 5 years. could trim a piece of plastic from something else and plastic weld it on. i have had some success doing that for other trim pieces
Old 07-27-2014, 10:51 PM
hooknladder's Avatar
There are two black metal clips that hold the switch panel in. Mine was missing one. Stealership charges around $1/clip for them.
Old 07-28-2014, 04:22 PM
warmeck's Avatar
i found the little metal clip it fell off inside the door panel just underneath the switch panel thanks guys!
speedemon
03-21-2015 02:13 PM
chevy
05-13-2013 11:54 PM
kamaro68
04-03-2008 05:20 PM
Deagle85
LS Series Tech
04-12-2007 06:02 PM
Quick Reply: really annoying door panel window switch
