Radiator Flush - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
Thread Tools Search this Thread
Old 03-31-2008, 07:52 AM
Default Radiator Flush
I have a new-to-me 95 3.4L that really needs a coolant change. How much coolant amI not going to get out of the engine ifI don't pull the block drain plugs and knock-sensor? I just have this bad feeling thatthose plugs will leak when reinstalled, so I'd like to avoid it ifI can (lots of Ohio rust!)
With all my older cars, I used to just flush and re-fill the system with water a bunch until it flowed clear out of the radiator, letting it run to get hot so the heater core got rinsed too. A friend recently told me I'm not getting the block flushed well by using that method.
2002 V6 T-Top
1995 V6 Convertible
1994 V6 T-top
Old 03-31-2008, 11:17 AM
LT1RUNNER's Avatar
Default RE: Radiator Flush
I would recommend taking the car to any local radiator shop and have them do it. Yeah it's going to cost a few bucks but there are three reasons for this. One: You make quite a mess by letting the water and old coolant run all over the place. Two: There are enviromantal lawsand if the po po find out what you"re doing then there could be a huge fine. Three: The radiator shop can clean and flush your radiator better than your best efforts can produce.Just my thoughts on the subject.
Old 03-31-2008, 05:22 PM
The Banks's Avatar
If you are able to change your oil and do other basic maintenance then you should be able to change your coolant yourself... you don't need to take it to a shop for that. When I changed my coolant the other week I got out about 2 gallons. After it was all drained I flushed it with water and ran it for a while with just water in there with the heater on. Granted I did it more than once so I could get out the 8 year old Dex-cool. I'm pretty satisfied with it and got out quite a bit of sludge that Dex-cool is famous for producing.
Old 03-31-2008, 10:04 PM
Thanks for the response, and I don't have a problem with confidence in doing this, but the question was about the drain plugs.
Reply
Thread Thread Starter Forum Replies Last Post
Radiator flush question Raven93 General Tech 3 04-19-2014 09:51 PM
Radiator flush???? Jeepin 70-81 General 3 11-16-2011 02:26 PM
Anti-freeze from my recent radiator flush leaked........ BoricuaHec01 LS Series Tech 9 03-15-2011 08:57 AM
Radiator Flush Citric Acid Question 94CamaroSFI 93-02 V6 Tech 2 08-03-2007 12:06 PM
85 camaro radiator flush ohiocopper12 82-92 General 1 02-06-2007 01:53 PM
Tags
1994, 1995, 2002, 94, camaro, carlo, chevy, coolant, core, fill, flush, hard, heater, lt1, monte, rad, radiator, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
