putting 96 into 94 lt1
Old 01-29-2013, 06:18 PM
Camaroboi22's Avatar
Question putting 96 into 94 lt1
What must i change for a 96 motor to work n a 94?
Old 01-29-2013, 07:34 PM
pretty much nothing, opti will work would need to leave the crank sensor in or plug the hole if it has one. i have a 96 intake, rack and front cover for newer style fuel delivery and vented opti. you will need the 96 opti harness that goes from the opti to the plugin on the passenger side of the intake. it will plug right in the 94 harness.
Old 01-29-2013, 08:19 PM
Smh i just notice that i had to switch the wire thats y my car wasnt firing. From me trying to start the motor it wouldnt throw any timing or anything off would it?
Old 01-29-2013, 08:33 PM
jkeaton's Avatar
Wait...96 is obd2, 94 is obd1...any pcm issues??
Old 01-29-2013, 08:47 PM
nope. and nope.
Old 01-30-2013, 09:51 AM
jkeaton's Avatar
Can you splain? From my limited knowledge, I understand the only big differnence between OBD1 & 2 is the number of sensors (post cat O2 being one I know of)...and the OBD connector (12 pin vs 16 pin)....None of this makes any difference?
Old 01-30-2013, 10:04 AM
The 96 engine is OBD2 compatible only because it has a separate crank sensor in the timing chain cover, which is used for diagnostic purposes. But that feature is not going to be used when put into an OBD1 car. The old and new style opti still sends the same ignition signal.
Old 01-30-2013, 11:08 AM
jkeaton's Avatar
ah...cool. Another option then for me when it comes to rebuild time. I'm not limited to 94 engines. I could put up to a 96 and not have to worry about swapping harnesses and stuff like that.
Old 01-31-2013, 07:18 AM
Thanks for the help i changed the distributor wire from a 94 to a 96 wire and it fired right up. I didnt know that the plug in is different. 94 plug in wire is shorter and wont make a connection but still will plug in but need 96 wire to make the connection. Thanks for help. P.s only thing that i changed for it to fire
Old 01-31-2013, 07:25 AM
i think the longer plugin is an attempt to do away with the moisture problem with water gettin in that short plugin.
Quick Reply: putting 96 into 94 lt1
