push button start
#21
^ One: Ok, cool...as long as somebody else sees it...and is impressed by it.
Two: If your key is messed up, you still have to bypass the VATS.
I don't get what you're saying "I couldn't get the key back outta the ignition without a seperate shutoff switch". Was your key always stuck in the ignition, so you needed to have a hidden starter button?
Three: I've done exactly the opposite before; hidden a switch that disables the starting mechanism. This way hides a switch that works the starting mechanism.
#23
so let me make sure i got everything figured out if i take the wire off the solenoid and replace it with a new wire that goes to the switch and give the switch power then when i hit the switch power should go to the starter
