Passenger side speaker cutting in and out.
Old 09-09-2007, 09:25 PM
BAN WS6's Avatar
Default Passenger side speaker cutting in and out.
While I'm driving my passenger side speaker has been cutting in and out. I took the door panel off and checked the speaker, working fine. As I put everything back together I checked all of my connections which seemed to be good, and the speaker was now working. I drive down the road a bit and the same **** starts up, cutting in and out and crackling. Nearest I can tell is that I have a loose connection somewhere. I'm not a stereo guy and was thinking of taking it somewhere to have it fixed. Anybody have a ballpark idea as to what it'll cost, assuming it's only a loose wire?
Old 09-11-2007, 07:29 AM
1994greenchevy's Avatar
Default RE: Passenger side speaker cutting in and out.
mine was doin that. but my speaker was blown out. i'd recheck it and go over everything real good.
Old 09-11-2007, 08:53 AM
8485Chevycowboy's Avatar
do u have an after market deck?? if so u can pull the deck out and check behide it.. or what i have seen in other cars is the boot that holds the wires between the dash and door(can b seen when u open the door fully) could b pinshing the wirewhen u close the door.. As for cost it will b to much. aslo another thing u can do if its after market is switch ur speckers wires just ur front from right to left just to make sure its the wires... hope that helps.
Old 09-12-2007, 01:45 PM
BAN WS6's Avatar
I'll check the boot like you said. As for the stereo it's all stock as far as I know. The only thing the guy I bought it fromdid was put in an amp and a subwoofer.
themadness
05-10-2014 11:54 PM
AmericanMuscle1989
10-17-2013 07:51 PM
DMateo
03-20-2009 11:51 PM
tirocz
82-92 V8 Tech
03-25-2008 05:38 AM
b4cmoose
06-06-2006 07:31 PM
Quick Reply: Passenger side speaker cutting in and out.
