obd 1i
Thanks for the reply, I have the 94 Z28, LT-1, 4Spd automatic, .
My problem is, It has gotten to where it will not start on the 1st cranking. Starts fine on the 2nd try. Fuel pres. is 48, new fuel reglator, new fuel filter. Fuel pres. will NOT hold after the pumps stops. Pres. holds at 43 with eng. running.
Anthing else ???
Anthing else ???
If its a leaking injector you should get a real rough idle at first as it clears the gas out. If it is a check valve just cycle the key on and off a few times. If it starts right up with no loaded up, rough sound it is probable the check valve.
I notices if I park facing down hill my car will start with one key cycle. If I park up hill I cycle the key 3 time.
