Need help with '98 Camaro audio system. - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
LinkBack Thread Tools Search this Thread
Old 03-03-2008, 10:52 AM
Default Need help with '98 Camaro audio system.
So I've come to the point where I have realised I need a new sound system in my Camaro, mostly due to the fact my deck doesn't accept cds anymore at all. Just says "Err" and spits em out. I went to a few places and they keep telling me I have to rewire my whole car so that I can put in an aftermarket deck which is really all I want. How did you guys go about doing this? The system in it now is the Monsoon one.
Old 03-03-2008, 11:07 AM
95slvrZ28's Avatar
Caretaker of Ban Hamster
Default RE: Need help with '98 Camaro audio system.
The places that you're going to are telling you the correct thing. The issue is really due to the speakers. They're 2 ohm speakers, which isn't a very common impedance, most aftermarket decks are made for 4 ohm speakers. Your Monsoon system also has an amplifier that is separate from the head unit, which further goes into overdriving the speakers. I was able to install an aftermarket Sony deck in my car but the CD part wouldn't work, only the radio, so I sold it and replaced it with a used stock unit. At this point you have to decide how much you're willing to spend on your sound system because unfortunately it's kinda an all or nothing deal.
Old 01-02-2009, 09:44 PM
On The Tree
As I understand it, the monsoon HU puts out 4 ohms, it's the amp in the back that changes the impedance to 2. Am I wrong on this?
Old 01-03-2009, 10:19 AM
Does the same hold true for the Bose units??? I was going to put in a unit that has a USB connector
thanks for this thread
Old 01-03-2009, 11:45 AM
same sort of question.. for me I have a 96 bose delco system, but its the cassette, want to replace it with the CD version and stay stock, patched in an fm modulator which will do for now. But where is the power amp located for the speakers??, my right hand one has stopped emmiting sound, dont know if it could be the amp. the power amp oir the speaker itself, the rear sub still picks up the right hand chammel but door speaker not. Do I have to take off the whole door panel to get the speakerr out as the sound shop said?. Easy job, any write up on this.
Old 01-03-2009, 03:29 PM
I can answer the question about the door panel and right speaker. Just follow the link for "replacing power window motor" the photos are excellent as to where the screws are located and tips for removing the door panel. I had to remove the speaker in order to replace the window motor
We still need help here on the Bose units. Can a Best Buy type of system work with those speakers?
Old 01-04-2009, 04:47 AM
thanks but cant find link for the door panel removal,with that search term, found one, but not the one you mention with photos which sounds ideal.
Old 01-04-2009, 08:14 AM
Quote:
ORIGINAL: oliverjohn
http://www.camaroforums.com/m_69247/tm.htm
Old 01-05-2009, 02:19 AM
lt4weeda's Avatar
just got to somewhere and but what they call a quick wire kit for your plug inso it adapts from your stock plug in into wire ends to wired up to the plug in for your new deck. and then all you have to do is run new wires to your speakers.
Old 01-05-2009, 11:25 AM
Thanks for the link
Reply
Thread Thread Starter Forum Replies Last Post
92 camaro audio system blows 150 amp fuse? kaoticjester Audio/Visual Electronics 3 01-09-2012 09:34 AM
95 z28 bose audio system Pig Hunter 93-02 General 25 11-22-2010 09:51 PM
Audio system Brutamalizer 93-02 General 1 09-04-2010 01:40 AM
Whats the best Audio system for my 95 camaro? xDeath General Tech 14 05-18-2009 12:14 AM
Tags
1998, 98, amp, audio, camaro, door, factory, location, monsoon, panel, remove, sound, speakers, system, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
