ncant read codes on 93 3.4
Old 12-12-2010, 11:00 AM
usc45cal's Avatar
Default ncant read codes on 93 3.4
hi guys new to the forum ,
i have a 93 3.4 im working on with an intermittent ses light , this happens at idle and if i tap the pedal the light goes out . my problem is i cant read the codes by grounding the dlc connector out , the fan comes on and the light is solid , i made sure those terminals were powered and grounded as needed so i tried out matco determinator which goes limp and says make sure the ignition is on , all of my fuses are good and im confused by the scanner saying that , it works on other vehicles fine and the owner just replaced the pcm for this problem,, any help would be greatly appreciated
thanks
jim
Old 12-12-2010, 11:20 AM
usc45cal's Avatar
yes sir an the fan as it should
Old 12-12-2010, 11:21 AM
the paper clip method should work. so your getting a continous light with no blinking?
Old 12-12-2010, 04:06 PM
usc45cal's Avatar
wow i thought someone else might have seen this problem , weird
Old 12-12-2010, 06:25 PM
yah its been on the site for a short while and i thought we had it fixed. guess not. if your not getting a 1 blink and a 2 blink then the diognostic program is not working. sure sounds like a short/gound in one of the wires.
Old 12-14-2010, 05:34 AM
usc45cal's Avatar
even worse , Mitchells wiring diagrams do not match the computer side of the car , i did find out the car sat for 2 years and did find a few wires chewed by rodents but still no luck
Old 12-14-2010, 11:26 AM
here is a link to my photobucket, there are many wireing diagrams for the 3.4 on it. rather than try and post them all you can look and see if any of it helps.
http://s1018.photobucket.com/albums/...y/attachments/
cmorgan
08-20-2011 02:49 PM
cdnturboz
08-06-2011 10:33 AM
aleksandr
01-01-2008 12:39 PM
MadMikeZ28
10-22-2007 02:36 PM
golfballs
01-28-2007 06:43 PM
Quick Reply: ncant read codes on 93 3.4
