Manual transmission fluid question
When I was putting in my MGW short throw shifter, I noticed the resivour was low on transmission fluid. does the resivour under the shifter need to be filled?
P.S. don't laugh at my stupid question :$
The fluid drain plug, and fill plug (above the drain) are on the passenger side of the trans. The cavity that you're referring to, where the shifter goes into, isn't a reservoir.
