injector size
what is your rated hp. or estimated hp. theres a post in the how to and faq sticky that tells the estimated injector for given hp. number 25 on the list here https://camaroforums.com/forum/93-02...62/#post557634
Just take your estimated rwhp and multiply it by 0.08 to get minimum injector size.
Ex. 400 hp x 0.08 = at least 32 lbs.
Go the next step up if you want more headroom for future upgrades. If 32 lbs. is your minimum then you should buy 36 or 37 injectors.
