Important window problem
on mine blue a ground black an red an brown positive ,yes the windows on these cars just plain stink ,just did my drivers to find it was the motor an before that is was working like new .put it down one day was it done,usally they give some sort of sign ,but if your getting power there then its the window motor ,while your there you may want to look into the 30.00 kit for giving the window extra power ,as they go slow after about a year any way ,it supposed to keep it moveing faster for passegers windows mostly ,they do not make it easy ,there is few times you can use a 3rd arm so I did mine with my friend I allways get the one with a new regulator white crease is what I used an plenty of it ,though its inside that matters ,I may get Auto trix passngers window fix it kit 93 -02 for both my cars as they both run slow an stick too,its one of those things that no one can tell you how with certain things ,you can get one AutoTrix.net 93-02 Camaro there is a link hear somewhere
ya I plan on doing mine both ,so your further then me with that try calling the place you got it from ,there is also a thread online about this kid that wanted one on both windows as well as the express up down module we hooked mine up to go up fast instead of down with the one second hold I think that's better for when it rains an pretty cool with it being hot right now up is good with AC
