i have a 1999 camaro ss
Old 09-22-2008, 09:44 PM
nazariol's Avatar
Default i have a 1999 camaro ss
i have a 99 camaro ss 6 speed i dont know what gears it has, and if i install a 410 gear what will it do?
Old 09-23-2008, 08:18 AM
carguy_z28's Avatar
Default RE: i have a 1999 camaro ss
It wont do anything if you already have them.
You probably have 3:42 or 3:73 gears, if you put 4:10's in then you'll accelerate faster, but lose top end speed. You'll pull harder through every gear though, lose some MPG on highway.
Old 09-23-2008, 09:55 AM
98ss4REAL's Avatar
and your speedo will be off till you get it fixed
Old 09-23-2008, 10:14 AM
Nessy's Avatar
If you put in 4:10's, you are going to accelerate faster. (The higher number the gear (even though the higher numbered it is is actually considered a lower gear) is how much difference you'll have. So, with 4.11's, you are going to accelerate faster than you would with 3:91, 3:73 or any lower (or actually higher) gear.
Like carguy said, your top end speed will drop and your gas mileage will be worse. Don't mistake these for how minor they actually are if you plan on city/street driving and racing. The gas mileage isn't terrible like people make it out to be, and you probably don't plan on redbarring in 6th (or maybe you do) very often, but it will only help 60' 0-60 quarter mile times.
Old 09-23-2008, 08:13 PM
nazariol's Avatar
thanks guys!
tgkerschner
11-21-2011 09:18 AM
nuttinchyllen
09-29-2010 06:58 AM
JDTSBLACKSSZ28
LS Series Tech
06-26-2009 11:02 AM
JDTSBLACKSSZ28
02-19-2009 08:47 PM
Quick Reply: i have a 1999 camaro ss
