opti spark going bad
well i have a newish opti in my 97 z28 and am cerious if those things just fail ad thats all she worte or can they fail work fail work ect. and could that be the cause of my car shutting off during driving, then starting back up hours later?
ignition module or coil will do that. i had a ignition module go and it drove me nuts. drive it a couple miles down the road and it would die. id go get someone to tow it home and when we got ready to tow it would start right up. i now carry an extra module in the car. yes a opti going can do weird things and u can get a bad new one especially if its not a gm performance opti. the cheap ones are not reliable.
i use high temp rvt on the o ring for the cap to help seal it up. i also use electrical grease on all the plug wires and the wire harness inlet. the coolant can set on the inlet and drip in through the seal.
