where does this wire go??
Old 08-20-2011, 02:54 PM
NorthernCrew454's Avatar
Default where does this wire go??
I had to cut this wire to remove my engine a while back, couldnt get my fingers in there, and now that i want to repair it i cant find the other end! Where does this hook up to?
Old 08-20-2011, 03:04 PM
little wire is the start wire that goes to the ignition, clean the crud off and see what color it is, should be a cut one the same color, what yr is your rig again
Old 08-20-2011, 03:19 PM
1994, does it run into the harness?
Old 08-20-2011, 03:24 PM
its purple also
Old 08-20-2011, 06:04 PM
yep into the harness. should be a purple wire at the harness.
Old 08-20-2011, 07:14 PM
thanks craby, i must have overlooked it, ill check it out tomorrow
Melissa Flournoy
05-01-2012 07:11 AM
9434V6
08-19-2011 08:52 AM
RatCamaro
01-29-2011 08:55 AM
hshawn31
01-13-2008 02:45 AM
twankieman91
12-19-2007 06:46 AM
Quick Reply: where does this wire go??
