Help with camshaft selection!
#22
Excuse me for changing the subject on your reply, but, now I'm looking to find a good set of roller rockers,studs, push rods and guideplates(?) (Do I really need new guide plates?) I've heard that 1.6 roller rockers with 7/16 studs is the way to go?
#23
i went with some from tpis https://www.tpis.com/parts/view/125 also got the rocker studs and pushrods from them. https://www.tpis.com/caryears/listParts/14 you might find them cheaper somewhere else.
#25
Also any push rods you might recommended for my future setup and sizing?
#27
#28
here is what i have, pretty sure the guide plates were comp cam
ARP 134-7103 7/16 rocker studs
Trick Flow TFS-21407100 Pushrods, 5/16 x 7.100
comp cam 1305 roller rockers 1.6 7/16 pro magnum
tpis performance roller lifters
#29
What are the plans for the car? NSA rockers and bigger studs are nice if you wanna go all out but if it's something isn't going to see any track time or very little, you're better of with SA rockers, imo.
I went with SA rockers and haven't had any trouble yet. I will switch to NSA when I go to a solid roller cam.
#30
Self aligning rockers or guide plates, you do NOT use both. And since the push rods can/will contact the slots of the guide plates, make sure you use good quality hardened push rods.
Edit for clarification: I'm referring to aftermarket performance guide plates, which have closer tolerances to the push rods, not some of the (sloppier fit) factory plates that were put there merely as an assist to engine assembly.
