Help with camshaft selection!
Old 11-25-2015, 04:21 PM
alex5366's Avatar
Default Help with camshaft selection!
Hey everyone, so from one of my recents posts in the past, I talked about getting my full exhaust. I did! I currently run pacesetter LT's, ORY, and magnaflow cat back 3" all the way.
Now I'm looking too add some more power and a nice choppy sound to my 1996 z28 m6 lt1 with 80k of miles. Keep in mind that I am looking for a cam that will not eat up my engine rarely quickly as it is a daily driver and I need to find a cam that won't kill my gas easy. Any one mind suggesting cams for a stock engine? I'm also looking into Lloyd elliots packages.
Old 11-25-2015, 07:22 PM
le2 heads and one of his custom cam is good.
Old 11-25-2015, 08:53 PM
alex5366's Avatar
What else would I need to buy to go with the heads? His website says ready to bolt on, but don't I need other things that go under the heads or even in the heads?
Old 11-26-2015, 01:06 AM
hardened pushrods and maybe some better rocker arms. i used 1.6 rollers to gain a little more lift. if you tell elliott what you are wanting to do he will tell you what you need.
Old 11-26-2015, 10:41 AM
95 camaro 406's Avatar
you want hp one of the best ways to get more hp at not a lot of cost is to port an polish the the heads an get about 40hp ,then go with a just over stock cam an your daily driver has more hp,
Old 11-27-2015, 11:27 AM
95z28man's Avatar
I'd like to get a mild cam eventually too with a new set of heads, possibly lt4 heads. Let us know what you settle on.
Old 11-27-2015, 02:40 PM
alex5366's Avatar
Sure will brother
Old 11-27-2015, 02:47 PM
alex5366's Avatar
Yea we spoke and he recommended everything else that I need to consider in buying. He's awesome! He recommends me getting this cam for my daily driver
223/231 .557/.571 110 LSA. He said it would give me tons of mid range torque. Also recommend me to purchase 4.11 gears. Only thing I want to figure out now is, how can I find a clutch that is like mines again. I've drove other maros and I have to let the clutch out pretty far in order for it to move, unlike mines I barely begin to release the clutch and it's ready to go. Any help with this?
Old 11-27-2015, 10:27 PM
sounds like the master or slave cylinder may be going. or you have lots of clutch left to use. lol. could be air in system too. assuming you do mostly city driving 411 should be ok. lol nowdays freeway is slower than city so i could be wrong. probly work fine all around.
Old 11-28-2015, 11:33 AM
MKCoconuts's Avatar
An OE style clutch will should keep your engagement where it's out now. The '97 M6 I have releases fairly quickly and it's got a newer clutch in it. The old one that was in it was worn out and didn't release till about 1/2 up.
Quick Reply: Help with camshaft selection!
