Hard start. Maybe fuel?
Old 03-21-2015, 08:17 PM
MKCoconuts's Avatar
Biggest line (3/8) is your feed line. The smaller (5/16) is your return line. There's another one on the pump for the evap. It's either 5/16 or smaller, I don't remember exactly. Did you replace the fuel filter as well? And did you use fuel injection hose and not regular rubber fuel hose? FI hose runs ~$8/ft vs regular fuel hose that runs ~$5/ft
Old 03-21-2015, 10:47 PM
rs657f's Avatar
<br />
Nice thanks and Yes I used the fuel injection one. I did put a fresh filter on as well. The weird thing about that is now both ends of the filter are male ends where the originally was female one side and male the other. Since I had to use a filter that wasn't specified for the car I'm not sure if that would make a difference. I tried to match it as close to oem as possible
Old 03-23-2015, 07:33 AM
rs657f's Avatar
I swapped out the recently installed pump with a new one, replaced hoses on all the lines. The car fires up good now. IT did last night as well but i didnt want to open my mouth until i tried it again this morning. Guess i may have installed it wrong or the pump was bad. Thanks all for the help!
Old 03-26-2015, 01:14 PM
95 camaro 406's Avatar
do you sue 93 octane ,some don't relize the hand book says to use 93 ,91 atleast
Old 03-26-2015, 06:04 PM
i ran regular in mine till the build with no problems. i think it performed better with regular.
Old 03-27-2015, 05:34 AM
rs657f's Avatar
I uSe 89 and occasionally 93. May run some 93 while I break the pump in (doubt it matters lol)
Old 03-27-2015, 10:23 AM
MKCoconuts's Avatar
I've always run 93 with the occasional mix of race fuel. The car seemed to like the octane better than if I ran regular. For the extra 20 cents a gallon, it's worth it to me.
Old 03-27-2015, 11:03 AM
Just so the OP doesn't get mislead... lower octane will hurt engine performance (timing retarded via the knock sensor), if the engine requires a higher octane.
But octane level has absolutely nothing to do with his hard start or a no start problem.
Old 03-28-2015, 06:25 AM
rs657f's Avatar
It says on the dash just use unleaded fuel but I do understand the gradual damAge cheap gas can do over time. My car is stock still so I figured 89 isn't too low in grade and too high in price. I def will be on that 93 baller level soon lol thanks again gents
  #20
Old 03-28-2015, 04:59 PM
I would not use anything less then 93 ,an like craby now that I have high performance engine I run octane booster ,anything less can couse valve knocking an premature wear ,your lt1 is a high perforrmance motor an it says it in the hand book an say not less then 91 on a rainy day ,I use 93 in everything it has a better shelf life to .oh my 2005 mercury sable runs fine on 87 , it was a high performance for those years an still is to me
Quick Reply: Hard start. Maybe fuel?
