gets up to temp then will not turn off
New to forum hot out searched could not find answer , I have a 1999 3.8 camero which when gets hot it will not turn off , runs without missing , with ignition switch turned off, so I replaced ignition switch , still does same thing .
I'm working on it now so if you have any ideas please email me at billymc38@yahoo.com or text 9102062468 it's 6-23-16 at 1:45 est
Please help
Thank tou
Bill
Please help
Thank tou
Bill
hay billy welcome to the forum. this is a strange one. moved your post and created a thread for you. do you have any aftermarket electronic stuff hooked up, stereo amps or other gagets, maybe a alarm.
Solution Engine running after turning off solution
As stated I had replaced ignition switch, with same result, after scratching my head and having a good look under hood , I found that the serpentine belt had come off in past and stripped several sensor wires loose . I found one going to engine cooling fan that was attached to the abs/ign fuse .
The problem would worsen when engine was hot , I rewired cooling fan and the problem has not returned. Did this for a friend.
Left new ignition switch installed , wasn't worth removing and installing old one !
Good luck to all of you and glad to know people still try to help others in need !
Take care
Billy
Take care
Billy
Sheriff420
82-92 V6 Tech
21
05-21-2011 09:24 PM
