Front turn signal on 94 Z28
Ok so what's the best way to get to the front turn signal housing? I've got a new pair to install and it doesn't look obvious. Looks like I need to remove the slash guard and go from there. Any info/advice is appreciated.
is this it?https://camaroforums.com/forum/93-02...acement-72317/ can be found in the how to sticky at the top of the general section. here, lots of good info. https://camaroforums.com/forum/93-02...62/#post557634
Thanks! Are there any special tricks to this? I attempted to change the turn signal bulb and that was ridiculous, I gave up and took it to the shop. But now that I'm changing both lenses I really need to do this myself.
have you downloaded the service manual? https://www.mediafire.com/?40mfgeoe4ctti click 1994 sec man. go to the electrical body and chassis section. should be directions on how to take them out.
