factory radio question
Old 10-13-2009, 01:05 PM
auto's Avatar
Default factory radio question
if i disconnect the radio fuse, how would i before if the theft deterrent is on or not?
Old 10-13-2009, 04:58 PM
Sez what??? If you remove power to the radio it won't work anymore until you punch in the proper code.
Old 10-13-2009, 05:01 PM
auto's Avatar
exactly, but how would i know if the deterrent is on or not before i go disconnect it?
Old 10-13-2009, 05:05 PM
siueparent's Avatar
I'm not sure but I disconnected my radio from the car and when I connected it days later it came right on.
Old 10-14-2009, 11:42 AM
GMDCAMARO's Avatar
It depends if the Previous owner has programmed the "Theftlock" Feature into the Radio. I have removed and installed mine multiple times without any problems.
So if it's been programed you'll need the Radio code, if not, you should be fine.
Old 10-14-2009, 12:42 PM
auto's Avatar
and if i dont know the code? and disconnect the battery?
Old 10-14-2009, 01:41 PM
osduck5's Avatar
I have the same problem with the 97 I bought. I did not have a battery in it and I put a new one in but can't get the radio to work. Guess the PO had the Theftlock turned on!
Old 10-14-2009, 01:44 PM
auto's Avatar
so what do we do?
Old 10-14-2009, 06:24 PM
osduck5's Avatar
Originally Posted by auto
so what do we do?
I guess we put on a good sounding exhaust and just guide and ride, listening to the afterburners! I don't even have a manual to tell me how to put it in the code for the theftlock. Maybe I look in my sons 96 manual, it might have something in there. I will check and see, if it is only a few numbers, I guess we could just figure out the statistics and go through every number until we hit the jackpot!
Old 10-14-2009, 07:15 PM
auto's Avatar
o boy, that`ll take a millenium or two, i think the password can be up to 4 digits according to my manual. if not think maybe the dealer could have something to master reset it?
Quick Reply: factory radio question
