exhaust manifold gaskets
vette headers won't fit, gotta be 4th gen lt1 headers. these vavle cover gaskets are reusable, need to clean surfaces good. you sure its not the power steering pump or the a/c it has oil in it too.
i am unsure what exactly it is all i know is its coming from near the exhaust manifold and its smoking like a mother ****er from burning. It just started happend after my mechanic did a valve job he did reuse the gaskets but as you stated that was ok.
i found it is the valve cover gasket leaking i can feel oil on the back side of it and the gasket in the back is basically not even in the valve cover its sticking out. u are right i shouldnt trust my mechanic i always gotta watch this guy lol. well good thing is that he is doing the build for me for free but i will be watching him with a close eye.
? bit confused you have spent 2500.00 on the engine ,an your mech works for free seems you could have bought a crate engine almost ,yes its the valve cover gaskets leaking oil to the exhuast ,port an polish should have been done when the heads were off ,its one of the best ways to get more hp ,when rebuilding
woh, its hard to get them gaskets in wrong.
get the exhaust and headers first. save for stroker unless your sure this one is a good engine, it is a good deal if it is. would not be kool to get it and find a crack after getting it all together. lt1 stoker short block done right in a good shop will run around 3k, at least last time i looked thats what they were. thow some le2 heads and ported intake with a custom cam and you got it. should gain good hp.
#20
yes be careful theres an lt1 build to 383 stage 2 kit 1599.00 ebay, lt4 short block 383 $3600.00,just some ideas i was going to buy a used lt1 before my wild swap ,1000.00 supoed to have had only 18.000 miles ,we just never know with used ,buy rebuilt or remanned an we get a better chance of a desent angine
