exhaust manifold gaskets
  #81
Old 10-10-2015, 09:03 AM
have you seen them? yes flex pipe sucks,,,, i mean leaks... exhaust shop can make the pipe whatever size you want with pipe bender machine. usually do your pipe for nothing.
  #82
Old 10-10-2015, 05:12 PM
warmeck's Avatar
yeah im going to a exhaust shop tomorrow and geting 8ft 3inch pipe and 4 elbows 3inches
  #83
Old 10-12-2015, 07:46 PM
warmeck's Avatar
so the guy was an overpriced ******* tbh so let me ask you craby do you know of any good exhaust kits under 200? that i can weld up to my headers 3inch pipe diameter. would this work?http://www.jegs.com/i/JEGS+Performan...30562/10002/-1 vs http://www.jegs.com/i/Dynomax/289/89000/10002/-1
  #84
Old 10-13-2015, 08:31 AM
have you got the y pipe? that would be first on the list
  #85
Old 10-13-2015, 04:01 PM
warmeck's Avatar
no i was going to try to make a custom pipe setup with that kit. are u saying im going to need that kit and a y pipe? i probably should go with a kit more like this then? http://www.summitracing.com/parts/sum-670147
  #86
Old 10-13-2015, 07:36 PM
depends on if you want to dump exhaust in front of rear wheels. running two pipes to the back will not leave much room for clearance. to run one pipe to the back you will need a y in the pipe.
  #87
Old 10-14-2015, 05:11 AM
warmeck's Avatar
Welly car is on stock config for stance it is not lowerd are u talking about speed bumps and such?
  #88
Old 10-14-2015, 05:36 AM
yep...
  #89
Old 10-14-2015, 10:11 PM
warmeck's Avatar
yep...
i see so no matter how i hang it up its going to hit regardless? thats dissapointing but i guess i will have to deal with it.
  #90
Old 10-14-2015, 11:49 PM
here is the clearance i have its pretty much stock Name:  P2290008.jpg
this one is with the first tunnel brace and it hit everything. give you and idea of how it crosses over too. i had to modify the y pipe by having it cut and one side stretched so it can be connected.
here is what i got. give you an idea of the y pipe looks like.
Quick Reply: exhaust manifold gaskets
