Dry start up with ignition 5 out of 10x? New starter?
Dry start up? I have a degree in automotive tech, GM and ASE certified tech what the heck is a dry start up? Is this a some regional slang for a certain condition? To me a dry start would be no fuel?
Since I do not know what a dry start is I can not really help but here are some facts.
All a tune up on these cars is new plugs/plug wire and filters. There is no adjustments or tweaking like there would be on an older car. Doing a second tune up in less then 5 years or 80,000 miles is throwing money away.
New parts fail, it happens all the time.
Diagnosing a cranking problem should have NO guess work in it for a mechanic with the correct tools. That assumes the mechanic can make the error happen with the tools connected.
I have had 20+ year old cars with chronic cranking and charging issues. First thing I do is replace the main battery cables. Large cables build resistance over time. This resistance will cause premature Starter and Alternator failure. It can even make seem like weak battery. This resistance is easy to measure in a voltage drop test but if I had a car that was 25 years old, it would be getting new battery cable.
the battery is fairly new and was replaced just before i purchased it in 2013.
but then again, the cables im not sure about.
But my backyard mechanic doesn't like to work on American cars, he'd rather work on imports like Japanese cars since they're easier to work on. I think it's common knowledge that a tune up on a Camaro is more difficult than a Toyota Camry, because of placement of spark plugs for example on a 4th Gen. Camaro, for example.
billyboy
12-11-2011 03:53 PM
Sheriff420
82-92 V6 Tech
21
05-21-2011 09:24 PM
rakoolo
10-04-2008 12:49 PM
