Driver's Window Sluggish on Manual Lifting and Lowering WD40 or something else?
TITLE: Driver's Window Sluggish on Manual Lifting and Lowering WD40 or something else?
Hi, members
about 2 yrs. ago my window started to get real sluggish. It's a 4th gen. and has manual window release bars.
I sprayed WD 40 near all obvious parts of the window including the door slit
It didn't work well enough so I went to a car wash and they had an oil or cream that had more viscosity
after they asked for a disclaimer from any damage to my car since it was non-car wash related, the window went up and down better, granted the window was gucky for weeks thereafter, translucent almost and it took several washings to clean off the oil
should I spray wd-40 ... if so where else do u suggest it be applied?
do you all know the name of that type of oil the car wash company used. sorry, i forgot it and the car wash went out of business
im hoping it doesn't get worse and worse fast...
as a window arm for a 93 Camaro like the one I own will be a hassle. since my friend and i might have to go to the junk yard and disasssemble the Camaro driver's side door . and do some alignment also which is pesky
thanks, members.
Hi, members
thanks, members.
There's really not much that can keep your window from rolling smoothly other than gunked up grease in the internals of the door. I would suggest taking the door apart and cleaning out all the tracks and reapplying grease to those surfaces. Some grease on the crank gears would help as well. Also check to see if any of the rollers have any issues as well.
grease is the only thing that works, huh?
anyway, i have to have it done by a pro. it's a 2 man job, holding the window up while the door is cracked open and grease applied.
ty again
*I also wanted to know if spraying wd 40 down the window, on the window, in the window slit crack, and any where else needing it according to common sense, would ACtually do more harm than good?
do you know GreenArrow?
anyone else?
anyone else?
cos since taking the window apart, while someone holds the window up, and someone else applies grease to the pertienent parts is at least a 2 man maybe a 3 man job and entails time and money
in the meantime member-friends, can i apply wd 40 down the window slit etc.
as a temporary bandaid? or will it do more harm than good and don't do it?
thanx in advance for any more help
Spraying WD-40 down the window sill is a temp fix. You can do this yourself it's not hard. Hardest part is getting door panel off. After that it's cake. Might be annoying maneuvering around the door to clean the parts off, but it's not bad. One reason to be glad you have manual windows is that you don't have to replace a window motor. Those suck the first time. Just do a search for a guide on how to take the door panel off. Once you get that done, you'll see what needs to be done.
And you don't need anyone to hold the window up, it should hold up just as you have cranked up.
here are some things to look at, taking panel off and getting to regulator is same for manual and electric.
http://www.firebirdnation.com/pdf/windowreplacement.pdf
Power Window Motor
AutoTrix Install Instructions
Adjust Door Window
http://shbox.com/1/window_regulator2.wmv
Ls1/Lt1 Camaro Trans Am (Window Motor Install) - YouTube
Power Window Motor
Adjust Door Window
thanks for going the extra mile to help. i copied and pasted all this useful info. as an MS Word doc.
this is labor intensive work at any repair shop so im going to try to do this on my own before it gets worse and worse.
i like to nip things in the bud preventive maintenance.
thanks so much Craby
Power Window Motor
Adjust Door Window
Power Window Motor
Adjust Door Window
It's very easy, just be careful taking off the door panel as it has very weak tabs. You have to take all the screws out and then lift it up and out. There's no telling how many door panels out there that have broken off tabs. This whole job should take you an hour or so, a few beers, and a couple 4 letter words.
