crazy tach
Old 10-30-2014, 02:32 PM
mikilla's Avatar
Default crazy tach
Ok my tachometer goes crazy. reads zero then jump up and down then will read normal again for a few seconds then go crazy again most of the time it just reads zero.
It all started with my friend hosing off the engine witch messed up my alternator it would peg the battery gauge but I didn't run it like that for long maybe a few seconds, so I changed the alternator but while I was changing my alternator my friend left the radio on so my battery died so I bought a battery charger from a yard sale for a dollar I figured it was worth a try but the people put the red and black clamps reversed but I noticed it right away so was only on the car for maybe 5 seconds got everything done but then the tach went crazy what could it be? I was thinking a ground somewhere
Old 10-31-2014, 09:28 AM
what year and engine?
Old 10-31-2014, 11:14 AM
Tachs are known to go nuts if the battery voltage is low, but from your story it is possible that by connecting the charger in reverse some electronic component got fried.
Old 10-31-2014, 12:09 PM
A funky ignition control module can cause an erratic tach bounce.
Old 11-05-2014, 02:31 PM
mikilla's Avatar
Its a 93 v6 automatic, now it seems my tach works for a while when cold but ounce it heats up it goes crazy again, how do I go about testing?
Old 11-05-2014, 03:25 PM
not sure if the 93 v6 has the tach module i see its the white wire coming outa the icm
LittleMissKhaos
07-24-2011 12:00 AM
82v8z28
82-92 V8 Tech
04-10-2007 12:54 AM
00camaro00
General Racing/Tech
12-19-2006 08:53 PM
Quick Reply: crazy tach
