Which cold air intake is the easiest to remove and clean.Thanks
Old 04-24-2008, 08:14 PM
1995CamaroZ28's Avatar
Default Which cold air intake is the easiest to remove and clean.Thanks
Thanks
Old 04-24-2008, 08:21 PM
Spartan66's Avatar
Default RE: Which cold air intake is the easiest to remove and clean.Thanks
They are all basically the same. same design in theoryno?
Old 04-24-2008, 08:39 PM
95slvrZ28's Avatar
You need to throw up a "their all the same" option because there isn't going to be any difference...They all put the filter in the exact same place, so you have to do the exact same thing to get to the filter for all of them.
Old 04-24-2008, 09:24 PM
baseballer91's Avatar
isnt the SLP sliightly different? aka a bit more complicated?
eh its really not hard for the others you just need some one to guide it from the top
Old 04-24-2008, 09:50 PM
02StanGT's Avatar
I'm not sure what the problem is. Most filters don't need to be constantly cleaned...
Old 04-24-2008, 10:00 PM
i replaced mine the other week, idk how long it had been on there thing was pitch black and torn right through the middle
Old 04-24-2008, 10:19 PM
95slvrZ28's Avatar
The SLP system has 2 tubes, and thus 2 filters, but they all end up in the same place, so with the SLP system it just means you have an extra hose clamp to undo.
Old 04-25-2008, 12:59 AM
kaoss_11's Avatar
how hard is it to clean an intake filter? This sounds like a lazy question if anything
Old 04-25-2008, 01:01 AM
skylinrcr01's Avatar
Pop it off, wash it with water, then spray on filter cleaning crap, let dry, re oil, then reinstall. Easy peasy lemon squeezy
Old 04-25-2008, 09:33 AM
meteoralp45's Avatar
is it just me or was this the most worthless post in this thread
Quick Reply: Which cold air intake is the easiest to remove and clean.Thanks
