coil pickup for rpm's doing emissions
Old 10-05-2015, 03:07 PM
Bob Thompson's Avatar
Default coil pickup for rpm's doing emissions
On my '95 Camaro Z28, stock Lt1 my emissions inspector is having a hard time trying to get rpm pickup with either #1 spark plug wire (cannot get to) or using a proximity sensor. He moved all over the engine with that and the rpm's are very sporadic. Does anyone know the best way to attain a good rpm read on these engines. Thanks much, Bob
Old 10-06-2015, 12:11 AM
He can use the diagnostics connector. Find a different inspector, this one shouldn't be allowed to do emission inspections.
Old 10-06-2015, 12:51 AM
number 1 plug wire is the easiest to get to,,, what is being used to try and get a reading?
Old 10-06-2015, 09:49 AM
Z28pete; are you referring to the OBD1 connector? He does use that and his diagnostics machine is a brand new 20K unit. No need to be sarcastic, he is well qualified. And craby; he is using a proximity sensor, much like a spark plug connector but all you need to do is get close to a wire. It senses the discharge to a plug by induction. Thanks for the replies guys.
Old 10-06-2015, 10:36 AM
What the emissions guy is trying to do would work for hooking up a timing light, not a tach. You need an ignition pulse for the tach, not spark at the plug wires. But Pete was right, the guy doesn't know what the hell he's doing. The best place to hook up the tach would be on pin A13 at the PCM: http://shbox.com/1/1995_pcm_conn_a.jpg
Old 10-07-2015, 03:06 PM
i have a voltage tester like that and had no problem getting it on number 1 wire before i changed to a coil per cylinder setup.
sl1foru
VS
10
10-22-2008 12:28 PM
mloaks
05-08-2007 04:52 PM
speedy9220
07-31-2006 10:03 PM
Quick Reply: coil pickup for rpm's doing emissions
