changing fuel injectors
I am having some fuel pressure issues as well as some other mess. I am looking to change out my fuel injectors. I have a 95 stock z28. I am looking at changing the current injectors to Denso. The are 24lb injectors which im sure is the same amount of # the stock injectors are. Would i require a tune for this or would it be a plug and play type deal? Thanks
Just make sure the coil resistance is the same as the OE injector.
If a low resistance injector is put in place of a higher resistance injector, the ECM driver will burn out/break due to the extra current demanded.
No re-program is needed, ECU will learn on its own.
if you want to know if there are issues with the injectors you have in the car you can take or send them to a injector shop and have them cleaned and flow tested. a while back i did and found a couple where not flowing correctly.
Lol I am actually at a car shop now getting the stock fuel injectors cleaned. I was supposed to be getting the refurbished ones today but the guy didn't ship them on time and I don't have patience at the moment. Wish me luck
Update; alright let me know if this was a dumb move. I replaced my fuel injectors on my 95 z28 with some ford denso 24#. I am know getting a high rpm idle around 1200? It doesn't drop down and I have a check engine light. It's running hard but doesn't smell rich. Kind of nervous to drive it to oreilly for a diagnostic since they're the only ones who have the obd1 setup. Any ideas?
Uh oh I actually did clean the iac it was full of dirt and the throttle body was full of crap and needed a new gasket. I have removed the tb a couple of times without issue before. I also am missing the tb plate gasket that's coming in this week and will be replacing iac as well. Ill check the injectors again im hoping that gasket missing on the plate may be causing this. Thanks for responding
DashingDaryl
05-21-2012 07:11 PM
