car lacks power with heater or ac on
Old 11-02-2014, 08:19 PM
gofastturnleft70's Avatar
Default car lacks power with heater or ac on
ok I got a 2002 Camaro 3.8 I bought it a couple of months ago and I put a new mas sensor in it because it was sputtering at lower speeds. car runs a ton better still has a slight hesitation at take offs. anyways if I try to drive the car with the ac or heater on and im driving about 40mph or slower or every time I have to stop and go car has very little power and does not want to run it surges and hesitates very bad. basically if I roll up to a red light or know I have to stop I go ahead and turn it off so the car will have power to go again. makes no sense because car is awesome unless im trying to drive with heater or air on... all tune ups have been done and new fuel filter.. any suggestions...??? thanks..
Old 11-02-2014, 08:31 PM
sounds like the compresser is going south, try unplugging it.
Old 11-02-2014, 09:29 PM
thanks' craby I will try that tomorrow after work.. so im assuming the ac compressor helps run the heater side to?? would that also maybe cause the slight surge/ hesitation at take offs to without the heater or air on to? thanks
Old 11-02-2014, 10:29 PM
When the heat is in the defrost position, the AC cycles to remove interior humidity. So yes, a locking up compressor could be the cause of both.
Old 11-02-2014, 10:31 PM
ok thanks for the info and help I will see what it does tomorrow unplugged. thanks guy's
Old 11-03-2014, 06:13 PM
seems to be the problem thanks guy's.. one last question is there any certain brand to buy or stay away from thanks only asking because I see a heck of a price difference between a part store compressor and some on ebay....im asking because ive never had one go bad so haven't been down that road yet...
Old 11-03-2014, 08:38 PM
i have not bought one yet. sorta in the same boat, mine is starting to leak. i looked at what rock had and they had delphi and four seasons that i was picking between.
Old 11-04-2014, 06:35 AM
fbodyrs96's Avatar
I've been running a ebay compressor and accumulator kit for almost 5 years no issues.
Old 11-04-2014, 06:36 AM
do you remember the brand name?
Old 11-04-2014, 08:10 AM
torque_is_good's Avatar
+100
I can't recall the brand but it was an active seller who carries lots of AC stuff
Even with my 30% discount at advanced auto the Ebay compressor, accumulator and exp valve was $100+ cheaper
When a friends Mitsubishi had the compressor go, we found one on ebay for $75. Come on, $75???? It worked great and continues to work and it was reman'd
Quick Reply: car lacks power with heater or ac on
