car cranks but won't start... full vats bypass
Old 09-18-2014, 02:51 PM
peter_x's Avatar
Default car cranks but won't start... full vats bypass
I have a '96 3.8. After completing an engine swap, I tried to start the car but the security light was on. I tried a different key and it worked. I ran the engine a couple minutes and shut it off. I didn't try to start it for another couple weeks because I decided to take out the transmission and rebuild it. I got it all back together, but the car had the security light again and wouldn't crank. I tried the resistor bypass, nothing. I got the pulse generator and hooked it up to the pcm, grounded the theft deterrant relay, and now I can get the car to crank reliably, but not start. When I crank it, I can see exhaust coming out the pipe, so I know it's somehow firing, but it doesn't want to start. The only thing I have observed is that the idle bypass valve sometimes seems to go haywire. I can hear it clicking open and closed even without the key in. I figured maybe the car isn't starting because it's stuck closed, but I get the same result even if I hold down the pedal while cranking. I'm pretty much at a loss so any help would be appreciated. Thanks.
Old 09-18-2014, 03:58 PM
Most likely what you see coming out of the exhaust is vaporized fuel, which could mean that the injectors are working, but the ignition might not be.
Old 09-18-2014, 04:58 PM
peter_x's Avatar
I'm getting spark at the one coil terminal I checked... I suppose I should check the rest though. The exhaust did smelled burnt, not sure how well.
Old 09-18-2014, 06:05 PM
While you are at it, you may want to look at the plugs & see if they are fouled or wet with fuel.
TNDawg123
02-26-2018 12:05 AM
GlennD
05-03-2013 09:38 PM
Graphite07
03-09-2011 04:58 AM
randyf
08-17-2010 09:23 PM
randyf
08-14-2010 08:27 PM
Quick Reply: car cranks but won't start... full vats bypass
