A/C blowing out bottom
Old 05-04-2015, 06:34 PM
tarheel's Avatar
Default A/C blowing out bottom
I have a 98 Z28 and the A/C is only blowing out the defrost and bottom. I've been told it's a vacuum line. Where would I find the vacuum lines for the A/C?
Old 05-04-2015, 08:01 PM
so even when you put it on defrost it still stays on split level.
Old 05-04-2015, 08:03 PM
theres a vacuum line in the engine compartment. maybe its damaged or unhooked. should be on the passenger side and go into a wire harness. that line feeds into the heater controls under the dash. from there the lines go to the control valves.
Old 05-04-2015, 09:09 PM
tarheel's Avatar
Yes. No matter what i put it on it blows out defrost and feet.
Old 05-04-2015, 09:47 PM
check the vacuum line under the hood. it hooks up to the passenger side of the intake manifold and should go into the passenger compartment wiring harness. do you hear a sucking noise inside the car when engine is running?
Old 05-05-2015, 06:24 AM
tarheel's Avatar
No. I don't hear any sucking noise inside car.
Old 05-05-2015, 02:31 PM
check the vacuum hose under the hood and make sure its hooked up and not damaged. should be the only one that goes away from the engine.
Old 05-05-2015, 06:48 PM
tarheel's Avatar
I guess I'm looking at the right line craby. Look good to me but I'm probably looking at the wrong ones.
Old 05-05-2015, 08:23 PM
does it go into a wiring harness or into the firewall? should go to the passenger side of the intake manifold. have a look at this 1998 HVAC hoses/lines, how to route and connect? - LS1TECH
Old 05-05-2015, 09:25 PM
GaryDoug's Avatar
There is a small t-fitting between the a/c evaporator unit and the pcm at the firewall. See if it is broken or if any of the three small hoses are disconnected. The photo is for a 95, but the 98 fitting is the same and in the same location.
http://shbox.com/1/vac_check_valve.jpg
Quick Reply: A/C blowing out bottom
