Body Control Module Repair
#74
Check your repair job and make sure no solder flowed from one point to another one that it shouldn't be touching.
You did remember to reconnect the harness to the BCM?
#75
My son didn't disconnect the battery when he unhooked the body control module the solder didn't flow over . Connected everything. Can you think anything else?
#79
My 99 Z28 does sound like it has the BCM issue, however when the radio goes off I slap the dashboard and it comes back on? Do you think it might be a loose wire and if so how do I get to it to fix it? I am Not a car DIYer but I can follow directions and can use basic tools. I would have to have someone repair or replace the BCM if that is the problem but would like to start troubleshooting with the least expensive fixes first. Any advise you could give me? Also, Thank you for the reference to the Military as I am the Spouse of a Retired Navy Veteran.
