Battery Drain
Old 07-15-2007, 08:18 PM
jpucci's Avatar
Default Battery Drain
I never had an issue with my 2000 I took it to a body shop to have some touch up done on it. When I picked it up the shop tech left the key turned and the battery was drained. It jumped right away and everything was fine. Now since then periodically it has no battery power when I try to start after it sits for 24 to 48hrs. I put an OPTIMA red top in in March of 2006 so I dont think its the battery. I am thinkin it may be alternator? but not sure? Any help or suggestions would be great.
Old 07-16-2007, 04:18 AM
Danscamaro02SS's Avatar
Default RE: Battery Drain
Hey if it was the alternator it wouldnt jump start it might for a sec but will shut off shortly after just recharge the batt then it will be fine trust me i had the same problem with my K5 Blazer.
Old 07-16-2007, 06:36 AM
jpucci's Avatar
Thats what I figured but wasn't sure. I put the batt on charge today and see what happens. Thanks for the reply
Old 07-17-2007, 09:45 AM
Reaper3000GT's Avatar
Try a diffrent brand of battery if thats not it take it back to the shop and ask em' why its doing what its doing.
Old 07-17-2007, 06:54 PM
jpucci's Avatar
Went to SEARS the battery checked out OK. Now I have to figure out whats pullin from it to drain it. Any suggestions other than the basic dome light glove box light stuff? I will probably take it in to the shop to have them run some tests unless anyone else has some at home tricks
Old 07-17-2007, 07:09 PM
us11csalyer's Avatar
You could try putting a multi meter in par with the neg battery cable. See how much is running through it after you shut the car off.
Old 07-17-2007, 07:47 PM
bluovlh8er's Avatar
is the glove box light stayin on?
Old 07-17-2007, 08:38 PM
jpucci's Avatar
I'll look into the multi meter thanks. The glove box light is definitly not on I checked that several times, andman I wish it was that.
Old 07-17-2007, 09:54 PM
usarmyrangrs's Avatar
It could be any number of things if you have a parasitic draw. Antitheft modules are good to start with, followed by keyless entry modules. My good friend suffered a periodic drain and after some investigating, I found that his keyless entry module was, for some reason, malfunctioning, this draining his battery. If you had an alternator problem, you'd notice it within a few minutes of driving and ultimately shut down the vehicle. To verift this, start the vehicle and measure the voltage of the battery. It should be constantly charging at 13.5 to 14.5 volts. If so, I'd be more than certain that an alternator is out of the question. If you have time that will allow, try parking the vehicle and checking the battery voltage with a multimeter every 15 minutes for two to three hours (but make sure the engine is not running, or that the key is in the 'ON' position). I'd then record the numbers and get an idea of how much was being lost.
BZpbp
11-07-2012 09:22 AM
frmjersey
02-12-2009 05:29 PM
jpucci
08-19-2007 08:56 PM
86 camaro
06-08-2007 01:28 AM
Tom97V6
04-07-2006 06:40 PM
Quick Reply: Battery Drain
