Another hard start/ no start...
This does not sound like a sensor issue. Next time the car will not start try holding the gas pedal to the floor and crank it. This should turn off the fuel flow. You could also pull a plug and see if it is wet.
New twist. I could not get it to start and finally got a noid light. I unhooked an injector to test, it almost fired. So I unhooked 2, and it fired right up. So my question is, is it possible to have an injector that shuts properly (because I've pulled the rail and turned the key on with no leaks) but then opens maybe too much??
Sheriff420
82-92 V6 Tech
21
05-21-2011 09:24 PM
