99. 3800 driver window stuck... down
.found it.behind the radio . clicks .when you go down with switch an yeaks when going up ,so replace switch first ,then WHO KNOWS not getting much.help hear whats new right ,then go from thereguess no one knows way a to just get the window up jumping it something hear ????????? 2 days now
look at the wiring number 13 here 4th Gen LT1 F-Body Tech Aids should tell you what wire need power to go up
thanks but were still at does the express. down module affect the window going up I had it out still nothing happens an my research shows its only for going down not up ,trying a switch today from there ,I will pull .panal to the door an check the motor ,never seen one just go ,they allways go slowly from my experience ,an put the driver side under dash back together Auto znoe knows nothing about the express down mo.dule ? is there a part # for the 99 i guess they work for any year ,but one needs to get a used one as gm get 159.00 for the module ,25.00 for used one ,but is that affecting my.window from moveing is the ? before I rip the door panel. off,theres power to the switch just the yeak noice from module when I hit .button I cant be the only person has had this happen someone has to know how the express down module affects it going down or up or not found part # 12182126 for any would work firbird trans am Camaro rs z28 ,if the switch don't work my buddie will come look at it ne.xct week but its a pain. to have do.wn. stuck up would be fine for now with AC
ok not the switch got power to it.? can it be the module express down relay stoping it from moveing again ,from there its the motor or window out of wack .again I never seen a motor just go ,so before I buy a express down relay I need to know if thats it ,I have explained for down I hear click for up I hear a yeak is there a way to by pass it its the brown wire to the relay ,dam windows I hate them ,so help with that ,then I can move on an take door panal off ,4 hours..,an like said I got power to the switch drops from 12 volts to zero when you push the button up or down ,if I knew it was the relay that easyer to replace then the motor is ????? ..help
WOW.know one knows if the express down. module can affect my window issues ,I guess its a module an motor then ,I would hate to have a worse situation I have given a ton of info again not switch got power there .but it goes from 12v. to 0v when I hit the button ,so it motor or module an no one has .had this issue.it just seems funny that when I have an issues I get like one person an others .get the help they need ,I got it from hear couse I guess I ait getting the help hear thanks craby you tried I guess
i got power to the switch ,next week I will pull the door panal couse I am pretty sure the express down should not affect going up so I am going to order a motor regulator the price is right ,an if it turns ou.t .the module. affects it then a used one its 20.00 ,I am starting to think the motor or the window is out.of .wack. so for either 30.00 or $50.00 will fix it will try jumping it then .thanks craby will get it done now I will have .my buddie look at it ,darn windows ,we will aslo put another layer of undercoating on the car ,bye next year the underside should be a lot better,i know when it comes to electrical things they can be pretty tricky,nice if it was stuck up though instead of down oh well should be ready for inspection.in august ,my 95 is.good to.2017 so that a + the red one has AC for the. hot days comeing up
is it a new motor? the cheap ones can go pretty fast. or not. lol. sorta a crab shoot. i wonder if its jammed. i managed to find gm setups for both sides a few years ago and waited for mine to go. passenger side went first cause driver side was changed at least once.
#20
did you know the place you sent me they have a kit for the passengers side wich allways goes first an very slow ,they said it has to do with getting enough power to it an the kit is supposed to fix it $30.00, ya will find out if thats the case next Thursday when it cools down ,thanks craby since we got .no.other input from the peanut gallery ,the guy I bought it from said it was new ,but will find out ,with all the window issues I am very surprized the 300 others who read it know nothing about windows ,but will talk about the most odd things that should be for lonely threadsmy .pass side on both cars could use one I guess of those kits ,couse on the 95 its like only 2 .years old an was gm too ,
cornmuffin
07-24-2014 10:22 AM
