98 RS ls2 4l65e swapped
So I have a 75% complete ls2 swapped RS camaro from a donor 06 gto with 4l65e. I bought as a project. I have some questions about the wiring. I've got a 98 ls1 auto harness. My main questions are about the inside wiring. Will all my window motors and power locks still work and am I able to swap to the z28 gauges. This should get some sort of answers going.
By 75% I assume you mean it is hard mounted? Just a FYI GM did not make a RS in 1998.
https://camaroforums.com/forum/93-02...v8-swap-78734/
ok you got a 98 wireing harness 06 gto ls2 engine,??in what year Camaro 96 97 were the only year of real RS otherwise if the car has the ground effects kit its called a sport package people mistake them for an RS in 98 an newer so its 98 3800 an your putting a ls2 in it ,we want to see the pictures of this car ,post some an give more information would help you a lot,these builds are a big challenge ,got to see it
Flex
10-02-2010 01:42 PM
