96 Camaro 3.8 Stock Alarm
When the car get bump the horn sound 2 or 3 times and stops till bump again. Is there a way to set it to keep going off after first bump? Those 2 or 3 time is sounds ain't much of a awaking sound when sleep.
Thanks
Thanks
Turn the sensitivity of the system down.
In the trunk, next to the antenna, there is a small box with a ****/dial... just turn it down a bit at a time until you get it where you want it.
If you turn it down to far, it will be ineffective.
I Know about the sensor in the spare tire area.
MochaCaliGirl
08-06-2007 03:15 PM
Matt99camaro
VS
10-05-2006 03:19 PM
